View Current BSR Information
View the current BSR information to review the configuration.
You must disable static RP.
- Select PIM.
- Select Current BSR tab.
Current BSR Field Descriptions
Use the descriptions in the following table to use the Current BSR tab.
Name |
Description |
Address |
Shows the IP address of the current BSR for the local PIM domain. |
FragmentTag |
Shows a randomly generated number that distinguishes fragments that belong to different bootstrap messages. Fragments that belong to the same bootstrap message carry the same fragment tag. |
HashMask |
Shows the mask used in the hash function to map a group to one of the C-RPs from the RP set. The hashmask allows a small number of consecutive groups to always hash to the same RP. |
Priority |
Shows the priority of the current BSR. The C-BSR with the highest BSR priority and address (referred to as the preferred BSR) is elected as the BSR for the domain. |
BootStrapTimer |
Shows the bootstrap timer. After the bootstrap timer expires, the BSR sends out bootstrap messages. |
